CIT G Force case fans not spinning
jakesilvester19
I've just built a new PC with a CIT G Force case that came with 3 rgb fans, the issue is that whilst everything else works (including the lights on the fans) the fans wont spin. All the solutions ive found online mention a standard 3pin cable coming from each fan but im only finding a 6pin connection that was already plugged into the fan 'hub' when i unboxed it. Now i could just be being really dumb and missing the extra cables or something but i've looked around and not seen anything.
Told you i was being dumb, literally minutes after posting i found a 4pin fan connection on the hub and a 4pin cable plugged into the motherboard. Swapped it over to the and now the fans have life.
