Clans for Def posts
G
Guest
Guest
Archived from groups: alt.games.vga-planets (More info?)
Does anyone have a breakdown of how many clans are needed for specific
numbers of defence post?
I have a partial breakdown already but needs the clans portion to
complete it. http://vgap.net/defposts.txt
If you can add to it or have it already just post here.
Thx.
"A second factor in calculating the defensive strength of a planet's
population is the number of planetary defenseposts. Each planetary
defensepost adds to this portion of the defensefactor, at a value of
0.05 per defensepost. This total value (starting with one, for planets
with no defenseposts at all) is multiplied by the number of clans and
racial defenseratio. For example, 100 defending Birdmen clans on a
planet with 30 defenseposts defend at a ratio of 100 * (1 + 30*0.05) =
100 * 2.5 = 250. A Lizard planet with 100 clans and 40 defenseposts
defends at a rate of 100 * 10 * (1 + 40 * 0.05) = 100 *10 * 3 = 3000."
have a look at donovan
Op 2005-03-27, Stormbull schreef <host@vgap.net>:
The math itself is easy. Below 50 defense posts it is the same as the
number of defense posts. Above 50 it is (defense minus 50) squared
plus 50.
I have another format. It's for Phost but I don't expect any
differences with host in this part. Ignore the part about torpedoes if
your game does not allow planets to have torpedo tubes.
Clans Def Bm# Type Fig Tu# Type Kill Expl
1 1 1*Laser * 1* 1*Mark 1 Photon * 14 8
3 3 1 Laser 2* 1 Mark 1 Photon 14 8
5 5 1 X-Ray Laser * 2 1 Proton torp * 21 9
7 7 2*X-Ray Laser 3* 1 Proton torp 36 10
9 9 2 X-Ray Laser 3 2*Proton torp 42 18
13 13 2 Plasma Bolt * 4* 2 Mark 2 Photon * 12 40
19 19 3*Plasma Bolt 4 2 Mark 2 Photon 15 50
21 21 3 Plasma Bolt 5* 2 Mark 2 Photon 15 50
25 25 3 Blaster * 5 2 Gamma Bomb * 60 79
26 26 3 Blaster 5 3*Gamma Bomb 75 81
31 31 3 Blaster 6* 3 Gamma Bomb 75 81
37 37 4*Blaster 6 3 Gamma Bomb 85 106
41 41 4 Positron Beam * 6 3 Mark 3 Photon * 63 161
43 43 4 Positron Beam 7* 3 Mark 3 Photon 63 161
49 49 4 Positron Beam 7 4*Mark 3 Photon 72 176
99 57 4 Positron Beam 8* 4 Mark 3 Photon 72 176
171 61 5*Disruptor * 8 4 Mark 4 Photon * 202 220
579 73 5 Disruptor 9* 4 Mark 4 Photon 202 220
1074 82 5 Disruptor 9 5*Mark 4 Photon 215 250
1275 85 5 Heavy Blaster * 9 5 Mark 5 Photon * 185 375
1731 91 6*Heavy Blaster 10* 5 Mark 5 Photon 205 415
3771 111 6 Heavy Blaster 11* 5 Mark 5 Photon 205 415
4019 113 6 Phaser *11 5 Mark 6 Photon * 295 410
5091 121 6 Phaser 11 6*Mark 6 Photon 318 450
5979 127 7*Phaser 11 6 Mark 6 Photon 348 485
6939 133 7 Phaser 12* 6 Mark 6 Photon 348 485
9075 145 7 Heavy Disruptor *12 6 Mark 7 Photon * 500 533
11499 157 7 Heavy Disruptor 13* 6 Mark 7 Photon 500 533
14211 169 8*Heavy Disruptor 13 6 Mark 7 Photon 550 568
14450 170 8 Heavy Disruptor 13 7*Mark 7 Photon 575 616
17211 181 8 Heavy Phaser *13 7 Mark 8 Photon * 525 745
17739 183 8 Heavy Phaser 14* 7 Mark 8 Photon 525 745
25971 211 8 Heavy Phaser 15* 7 Mark 8 Photon 525 745
27939 217 9*Heavy Phaser 15 7 Mark 8 Photon 560 790
30675 225 9 Heavy Phaser 15 8*Mark 8 Photon 595 845
36531 241 9 Heavy Phaser 16* 8 Mark 8 Photon 595 845
48891 271 10*Heavy Phaser 16 8 Mark 8 Photon 630 890
49779 273 10 Heavy Phaser 17* 8 Mark 8 Photon 630 890
57650 290 10 Heavy Phaser 17 9*Mark 8 Photon 665 945
66099 307 10 Heavy Phaser 18* 9 Mark 8 Photon 665 945
79011 331 11*Heavy Phaser 18 9 Mark 8 Photon 700 990
85899 343 11 Heavy Phaser 19* 9 Mark 8 Photon 700 990
96771 361 11 Heavy Phaser 19 10*Mark 8 Photon 735 1045
109611 381 11 Heavy Phaser 20* 10 Mark 8 Photon 735 1045
120459 397 12*Heavy Phaser 20 10 Mark 8 Photon 770 1090
137691 421 12 Heavy Phaser 21* 10 Mark 8 Photon 770 1090
153714 442 12 Heavy Phaser 21 11*Mark 8 Photon 805 1145
170619 463 12 Heavy Phaser 22* 11 Mark 8 Photon 805 1145
175611 469 13*Heavy Phaser 22 11 Mark 8 Photon 840 1190
208899 507 13 Heavy Phaser 23* 11 Mark 8 Photon 840 1190
229491 529 13 Heavy Phaser 23 12*Mark 8 Photon 875 1245
247059 547 14*Heavy Phaser 23 12 Mark 8 Photon 910 1290
626 14 Heavy Phaser 23 13*Mark 8 Photon 945 1345
631 15*Heavy Phaser 23 13 Mark 8 Photon 980 1390
721 16*Heavy Phaser 23 13 Mark 8 Photon 1015 1435
729 16 Heavy Phaser 23 14*Mark 8 Photon 1050 1490
No damage assumed.
Base posts count towards number of posts for #beams and #torps only.
Base adds 10 fighter bays, and when base tech is higher base tech is used.
Planetary mass is 100 + #base & planet posts.
A * denotes that the item immediately before that has increased for this number
of defense posts.
Kill and Expl are the total kill and explosive power for one round of
firing with all beams and - if available - all torpedo tubes.
Maurits van Rees | http://maurits.vanrees.org/ [Dutch/Nederlands]
"The question of whether computers can think is like the question of
whether submarines can swim." - Edsger Wybe Dijkstra
