Clarification on Vista 32-bit to 7 64-bit...
jh77573
15
Okay I know you can't do a upgrade, i guess my main quesiton is that if I don't mind loosing all my information, can I do the clean install of Win7-64bit using the upgrade DVD? Do i have to back up all my data first?
Yes, you can use the upgrade disc to do a clean install.
http://www.mydigitallife.info/2009/10/27/clean-install-windows-7-with-upgrade-media-and-product-key-on-formatted-or-empty-blank-hard-drive/
And you definitely want to make a back up first.
