M misterfrasier Prominent Jul 20, 2017 1 0 510 Jul 20, 2017 #1 I have a dirty anti-static workbench mat that needs to be cleaned. Is it possible to use water and a mild soap to clean with or do I need the specific cleaners that are made for cleaning anti-static surfaces? Any insight is appreciated, thanks!
Solution COLGeek Jul 20, 2017 Mild soap and water should be fine. Wipe down with just water after cleaning to remove as much soap residue as possible.
COLGeek Cybernaut Moderator Apr 6, 2009 59,711 5,382 184,340 Jul 20, 2017 Solution #2 Mild soap and water should be fine. Wipe down with just water after cleaning to remove as much soap residue as possible. Upvote 0 Downvote Solution
