Click within the case what is it or is my CPU over heating
Steve Zadoorian
5
SO i have a Question My computer might be over heating i don't know ? i am
or what is it is i am getting werid click and when i play Game like League of Legend or my whole computer Freeze and or my screeen turn black
Most likely that clicking noise is your hard drive. Especially if you are getting freezes. My advice is get a new drive and transfer your data quickly. That clicking noise means failure is imminent, and if you have any important data that isn't backed up properly you will lose it.
These temps are ok but there is not much load showing so they should be. Clicking sounds (pun lol) like the PSU. If it is going bad and goes into protect mode you would hear a click from some models. Then the system would shut down.
Well take the side panel off of your case and listen to were the clicking is really coming from. It could be your Hard Drive or something else. Does it sound like a mechanical click or electrical? If it is coming from your hard drive then yes replace the drive as soon as possible because it will not last much longer.
