Hi all,
Received my H50-1 for my i7 as my old waterpump packed up, everything was working perfectly untill i started up windows 7 and installed a driver for my mouse. The PC needed to restart so i proceeded to do so but on the "shut down screen" the circle wasn't spinning, so i manually restarted my pc by holung down the power button. My PC starts up perfectly but there is no signal on the monitor?
Sometimes it boots gets to bios but its frozen. Got to windows and tried to delete the driver but it froze, restart but no signal. Got back to windows after 700's try and running well, proceeded to enable SLi and it changed screen resolution and froze, hard restart and same again starting but not signal. Last time in windows didnt enable SLi played a game all fine general pc usage went to check my temperatures and it froze and had to hard restart.
All the fans are working the pump is flowing everything is as should be, but no picture but also i hear a clicking HDD but others from the DVD RW+/- drive...
Obviously this isn't normal for just a CPU cooler change, please please please need help
Processor: **watercooled** i7 920
Memory: 6Gb DDR3
Hard Drive: 1.8TB total
Video Card:**SLi** GeForce GTX 275
Monitor: Hyundai 24" W240D
Operating System:Windows 7 Ultimate 64-bit
Motherboard: Gigabyte GA-EX58-UD4
need help urgently!
thanks in advance
Memory: 6Gb DDR3
need help urgently!
thanks in advance
