Clock speed dropping and causing FPS frame spikes
GBCypher
18
Hi guys,
Recently had a lot of problems with my PC but have just narrowed it down (I think) to my CPU's clock speed dropping. When idle or under a full load the clock speed goes from 4200MHz to around 1000 to 1400MHz. - Found it using CPU-Z
Any ideas on what it can be?
My Specs:
AMD FX8350 Black Edition 8 Core @4.2GHz
EVGA NVIDIA GTX 770 2GB
M5A78L-M/USB3
8GB Corsair Vengeance 1600MHz
240GB OCZ Agility III
500GB W/D 7200RPM
XFX PRO 550W
Thanks in advance.
Stock cooler? If not, what heatsink?
Sounds like it is barely able to keep temps under control. CPU may throttle down to prevent voerheating.
I suggest something like a Xigmatek Gaia, Cooler Master Hyper 212 PRO or Hyper 212 EVO. These are very good budget coolers.
Of those 3, the Hyper 212 EVO is the best and usually around $30 or less on sale. You need to spend 2x as much to get just 2-3c cooler.
I was able to push 4.4GHz @ stock voltage and barely hit 56-57c max under full load on my 8350 before I went to water.
Around 60C idle 🙁 Makes no sense as I have a great heatsink and a Zalman Z11 Plus case with a lot of airflow.
Around 65 whilst gaming. (Tested on BL:The Pre Sequel
