Solved it myself, thanks anyway. Just had to change the DRAM voltage from auto to the suggested 1.5V. I also did as you suggested, reverted the overclock back to the original 3.5GHz with the voltage set to 'auto', still hit 69 degrees in BIOS. Bear in mind during BIOS CPUs are under full load ("Because back in the days that DOS and BIOSes were first written, overheating was not really a problem, so there was no need to idle the CPU." - source: http://superuser.com/questions/446735/cpu-temp-very-hot-in-bios-but-okay-in-realtemp-speedfan). Either that's the case, and the stock cooler just isn't enough under full load, or it's showing the thermal margin as opposed to the temperature, which I highly doubt. Still, thanks for the advice.
