it is a bugcheck called because some hardware did not respond in a timely maner.
it can be something like a device driver failing to install on one CPU core while another core is waiting to use the hardware. (happends a lot with certain USB wireless drivers)
this can also happen if you are overclocking the CPU or GPU
normally, you would have to provide a kernel memory dump to figure out this problem.
The general fix will be to update the BIOS, and install the current device drivers from the motherboard vendor. If you plug in a old piece of hardware, you want to look for updated device drivers for it.
