Hi. I hope you guys have a quick and easy fix...
Problem: X Dock / Hot Swap drive bays will not recognize any hard drive I install in to the bay. Here's a quick synopsis of what I have done to troubleshoot the problem.
1. The drives are warm when I pull them out of the bay, so I know they are getting power.
2. Installed properly in the X Dock tray, with and with out screws to keep them from flexing / moving in the tray.
3. Installed the one 4 pin power connector to the back plate for the X Dock, and installed the two SATA cables to the Mobo SATA III ports.
4. Tested 3 different HDD's in each X Dock tray / bay. (The HDD's work, tested in other systems).
5. All drivers and BIOS are up to date, with no errors on the device manager.
This is part of a new build I just completed. Below are the spec's:
Case: CM HAF XB
CPU: AMD FX 8350 Black Edition
Mobo: Gigabyte 990FXA-UD3
RAM: G.Skill Ares DDR3-1866 32MB (4 sticks)
OS: Win 7 Pro 64 bit
Video: 2 EVGA 9800GTX+
Thanks!
Case: CM HAF XB
Thanks!
