L lisibraimi Prominent Nov 2, 2017 12 0 510 Aug 2, 2018 #1 wich one cools better and is probably quiter ? they are currently both at the same price in my country p.s im not overclocking
Solution nmb255 Aug 3, 2018 According to the manufacturers specs Noise: CM: 29.4 Dba DC: 21.0 DBa Neither has any spec suggesting heat dissipation performance. [a sadly missing measure] What a difference of 8 DBa means when it inside your case, with power and case fans also spinning is probably nothing.
feelinfroggy777 Glorious Dec 13, 2016 5,721 135 45,990 Aug 2, 2018 #2 The cooler master will definitely cool better because it has more heat pipes. As far as noise, they are gonna about the same with a 120mm fan. If you want it quieter, just buy a better 120mm fan. Upvote 0 Downvote
nmb255 Distinguished Aug 27, 2011 213 7 18,765 Aug 3, 2018 Solution #3 According to the manufacturers specs Noise: CM: 29.4 Dba DC: 21.0 DBa Neither has any spec suggesting heat dissipation performance. [a sadly missing measure] What a difference of 8 DBa means when it inside your case, with power and case fans also spinning is probably nothing. Upvote 0 Downvote Solution
