[SOLVED] CM ML120L AIO CPU Cooler additional fan
Jan 23, 2019
9
I am planning to purchase the CoolerMaster ML120L AIO CPU cooler, but it only comes with one fan. Is there a way for me to set it up as a push pull config? The other question I've got is, the only additional RGB CM fan I can find in my area is the MF120L RGB fan which has less fins than the fan that comes with the cooler. Will the MF120L fan work in conjunction with the AIO cooler for a push pull config?
Any advice would be appreciated.
Thanks in advance.
Yes you can use it in a push/pull config. But the Benefit is very minimal. If you run both fans at the same speed it won’t hurt but push pull won’t really help.
What are you trying to accomplish?
What are the rest of your parts list?
What is your case?
In a good case, a simple tower type air cooler is often more effective.
To answer your question, yes, it is generally possible to use two fans on a single radiator depending on the case.
There may be not much cooling improvement to compensate for the increased noise and expense.
