CoD WaW Wont read, any help appreciated.
GNETWORK UL
17
I purchased CoD WaW and received 2 copies through a mix up which I thought was pretty sweet but when I insert the disc it just continually makes repeating scratching as if attempting to read and will after a 10 minute wait, autoplay will show up, but it doesn't have the option to install but simply open folder to view files.
When clicking this it renders File Explorer unresponsive.
I have tried both discs and both act the exact same way.
I was wondering since I have a genuine key would it be possible to torrent the ISO and input my key? But would that also render me unable to play online?
Can you try to use the discs on other PCs? It's possible your disc drive is dying (they usually start being selective before they break completely).
