Help please,
I get a code 99 and an indicator light of no bootable device. This will be my second RMA if I can't solve this (same codes/LED - ASUS support no help). Let's assume it isn't actually dead and it is something simple, I have a few questions, please.
Board: Asus Rog Maximus VIII extreme
Ram: 32 GB = 2 sticks 16 GB G.Skill Ripjaws (shows as compatible in manual)
PSU: Corsair hx 1200i
CPU Cooler: (Tried more than one of these as well. Don't think it is the issue.)
Get lights, get fans, get system running through multiple codes and landing on code 99.
Question: What do I actually need for just a POST test? (First time build.)
First, I'm only trying to do a POST test. I thought all I needed for the test was a mobo, ram, and a psu. (The mobo should have integrated graphics.) Wrong? What is the minimum for a POST test?
Second, my mobo doesn't have a vga connection in back. I can DVI, HDMI, DisplayPort, or USB (can't remember which version right now, think only USB 3.1 or 3.0 options, no 2.0?). I have actually tried running the test with and without a keyboard and monitor attached (trying HDMI for monitor and USB for keyboard). (Again, have been thinking ((erroneously??)) that I shouldn't get a code at all if all is well. But even with the monitor and keyboard in, I get same code and LED. (When the monitor is plugged in it also says no connection.)
Tried checking the 24 pin and 8 pin connections multiple times. Have tried reseating the ram multiple times. Have tried moving the ram around (initially had different ram and tried that as well, don't think the ram is the issue). Don't think the position of the ram is the issue. Yes, have tried one stick (and different stick). Even tried all different ram (that was also compatible with motherboard) in all different positions.
Have tried CMOSing too after each RAM change of any kind.
I do not get any beeps. (Should motherboard integrated sound be functioning?)
Do not get into bios at all.
Manual says to use 24 pin and 8 pin (yes, using the CPU 8 pin, not a different PSU connector). Have not connected the 4 pin in addition, because manual specifically shows that as an OR option (if you aren't using the 8 pin).
Have *not* tried using a graphics card for the POST test. Unsure what should or should not happen if no monitor or keyboard connected. Clearly, I can't hit delete key to enter into bios without at least a keyboard and won't see the bios without a monitor, but what should the computer do if I don't ask it to enter into bios? Why is it complaining about a bootable device? Do I need to connect up one of SSDs as a minimum requirement?
Have not flashed the bios. (Was afraid that might cause RMA problem if I attempted to do so.)
Last I checked, no bent pins. Would prefer not to have to disassemble and check that again.
Your recommendation for a first time builder, please. Never would have tried without a monitor or keyboard if someone hadn't suggested it, so be gentle if you found that ludicrous. Otherwise, assume I don't have a clue.
Thanks very much for your help. This is stressful.
Boondock
Boondock
