E elfingreen55 Prominent Oct 25, 2017 1 0 510 Oct 25, 2017 #1 Trying to get my Gateway sound to work. Coffee was spilled on my keyboard. Cleaned the inside and out side, but sound keeps going out it will work fine then it will just go down untill there is no sound
Solution hang-the-9 Oct 26, 2017 Not much you can do for spill damage. If only issue is the audio, find a replacement jack and install the new one that may help.
hang-the-9 Titan Mar 25, 2010 60,372 1,078 152,940 Oct 26, 2017 Solution #2 Not much you can do for spill damage. If only issue is the audio, find a replacement jack and install the new one that may help. Upvote 0 Downvote Solution
