Hello, today I found out that I can't use cmd.exe When I start it, it opens for a split of second, then instantly closes and instead opens File Explorer. Same happens even in Safe Mode. I ran few malware tests, but it was all fine. Please help
Try creating a new admin account. Then use that account to log in to Windows and try again.
Its updated to latest creator update. Made 2nd admin account, cmd worked fine, ran sfc scan but result was: Widnows Resource Protection did not find any integrity violations. I guess my main account is corrupted?
You have a mis-config/mis-setting issue of some sort in that account. What, if anything you can recall, did you change/install/remove before the problem started happening?
Well, I haven't used it for a while, but I have Test Mode activated, because I had to install monitor's driver, which didn't have signature.
