Compatibility and mobo/cpu help; Gaming
iare
HI, this is my first time building a gaming pc - or any pc for that matter, and I am having difficulty figuring out if everything will be compatible and choosing a mobo/cpu; help would be greatly appreciated and any suggestions to change out parts would be very helpful as well, thanks in advance.
PS: My budget is $500ish (ish = for taxes)
PPS: I am looking to play skyrim and writing documents exceeding 1000 pages
Help choosing mobo/cpu and wondering if they are compatible, Thanks!
Motherboard: ASUS Z77-A LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel
Price: $79.99
Processor: Intel Core i5-3350P Ivy Bridge 3.1GHz (3.3GHz Turbo) LGA 1155 69W Quad-Core
Price: $179.99
or
Motherboard: ASUS M5A97 LE R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD
Price: $74.49
Processor: AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core
Price: $119.99
and the rest of build is the same
Would it be compatible with both of the mobo/cpu combos above?
Power Supply: Thermaltake TR2 TR-500 500W ATX12V v2.3 SLI Ready CrossFire Ready
Price: $24.99
Will this be enough power?
RAM:G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Price: $89.99
Graphics Card: ASUS GTX650TI-OC-2GD5 GeForce GTX 650 Ti 2GB 128-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready
Price: $139.99
Tower: Unsure
FINAL
ASUS Z77/i5-3350p and rest of build
Price: $514.95
ASUS M5A97/AMD FX-6300
Price: $449.45
Thanks!
with that GPU the amd fx processor will be enough and its cheaper so pick the amd cpu
and for skyrim you should run it on high-max with no trouble unless you mod it like crazy with enb and highres textures
if you plan to upgrade to a new graphics card in the future and play more demanding games ... then the intel cpu will be a better investment
Why not 1150 build?
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($189.98 @ SuperBiiz)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard ($84.99 @ Amazon)
Total: $274.97
(Generated by PCPartPicker 2014-01-31 06:26 EST-0500)
mATX mobo is bit cheaper.
http://pcpartpicker.com/part/msi-motherboard-b85mp33v2
I think better buy is AMD 8 core cpu 8120 or 8150.
http://pcpartpicker.com/part/amd-cpu-fd8120frgubox
http://pcpartpicker.com/part/amd-cpu-fd8150frgubox
Id buy better psu.
http://pcpartpicker.com/part/evga-power-supply-120pb0750kr
Rosewill cappstone is outstanding psu. Really good quality and long warranty.
http://pcpartpicker.com/part/rosewill-power-supply-capstone550
Good quality tower is bitfenix ghost.
http://pcpartpicker.com/part/bitfenix-case-bfcgho300kkn1rp
Ah not anymore at 70$ price.
So then look other cheaper case. Fractal R4 is good option.
Corsair 200 and 300R is good cheap option.
Tractal core 3000 is good too.
Souda: So are you saying that the fx build won't be able to support skyrim mods? Like say 10-15 smaller mods and dlc? Also the mobo for fx won't be able to upgrade to a better graphics card later? Thanks.
AxlFone: The intel i5-4440 has an integrated graphics card, isn't that the harder kind to install discrete? I have a i5-2720qm with a pcie slot that I just can't get to work with a gtx 650 ti. Also, is the AMD 8 socket obsolete? It was originally my choice processor, however, I've read on the forums that it is negligible to fx 6300? I will defininetly buy a better psu and I like the corsair 200 - will look into that some more. Thank you.
mods like enb and high res texture replacement mods will really stress your pc
things for example that add a ton of npc to cities and trees and things like that will also stress your pc alot
light mods / effect mods also stress your pc from small for low quality to ALOT for high quality ones
small mods however like ones that change arrows speed/damage overhauls crafting / add new crafting schemes and so on will have no effect on performance
about the mobo its pci e 2.0 not 3.0 while its compatible with 3.0 cards you might just want to pick one that is pci e 3.0 so you wont run into any bottlenecks due to low bandwidth especially if you pick the 280x or upgrade in a couple of years
so just think about it ... will you be sure you wont play a different game than skyrim ? and wont mod it alooot ?
if the answer is yes then just stay with amd
if no go with intel
