Hello Tom's hardware !
So, I've been working on this build since yesterday and I wanted to know if I picked the correct parts and if they are all compatible with each other(I picked some components from a youtuber)
And I'm using pcpartpicker.
I also want to know what precautions should I take and some little advices and tips.
Here's the link : http://pcpartpicker.com/list/BNswVY
Also down in the compatibility notes it says : Some AMD A88X chipset motherboards may need a BIOS update prior to using Kaveri CPUs.
If my mobo doesn't support this cpu before updating it, how can I update it?
Any help would be much appreciated.
P.s: It's my first build attempt
