R rightchea Honorable Jan 23, 2016 32 0 10,530 May 22, 2018 #1 so this is more about compatibility between manufacturers and not the DDR4 itself. I have been reading that ADATA XPG GAMMIX D10 has been having issue with other manufacturers. has anyone else have those type of issues?
Solution T T TJ Hooker May 22, 2018 rightchea : So are you saying even if I buy the same RAM at different times it might be a problem Yes, potentially. The only time multiple RAM sticks are guaranteed to work together is if they all came in the same package.
why_wolf Splendid Aug 28, 2015 3,626 171 27,090 May 22, 2018 #2 you mean other RAM brands? This is true of all RAM. Whenever possible you should avoid mixing and matching. Upvote -1 Downvote
SkyBill40 Distinguished Oct 11, 2013 1,757 86 20,940 May 22, 2018 #3 It's advisable to always consult your mobo's QVL before buying anything to ensure compatibility. Upvote 0 Downvote
T TJ Hooker Titan Ambassador Apr 15, 2014 11,566 1,728 72,390 May 22, 2018 #4 You can run into issues combining RAM that was purchased in separate kits, even if both kits are the exact same model from the same manufacturer. Upvote 0 Downvote
R rightchea Honorable Jan 23, 2016 32 0 10,530 May 22, 2018 #5 So are you saying even if I buy the same RAM at different times it might be a problem Upvote 0 Downvote
T TJ Hooker Titan Ambassador Apr 15, 2014 11,566 1,728 72,390 May 22, 2018 Solution #6 rightchea : So are you saying even if I buy the same RAM at different times it might be a problem Yes, potentially. The only time multiple RAM sticks are guaranteed to work together is if they all came in the same package. Upvote 0 Downvote Solution
