Compatibility of Asus strix R9 380x with lcd monitor
Hasin_Sadique22
Commendable
Sep 26, 2016
46
Hi,
My config is
I5 6500
Msi H170 gaming m3 6th gen
Ram: Team elite u-dimm ddr4 8 gb
Psu: corsair vs 550w
Gpu: asus strix r9 380x
250gb hdd
I have a lcd monitor with 1280X720. My question is can I play games atleast in 720p?
Your monitor is a 1280x720 monitor. You can support max of 1280x720. You can lower it for resolutions like 1024x768 but you cant increase it for 1920x1080
What do you mean by that? A 380x can easily handle 1080p gaming, 720p is a breeze. One thing that isnt good in your build is the power supply, the VS 550w is a poor quality power supply, and the 380x is a guzzler. Yes it will be compatible with the monitor.
Are you sure?
http://www.in.viewsonic.com/za/products/lcd/VA1701wb.php#pSpecs
This is my lcd monitor's specification...ViewSonic VA1701wb. It's quite old.
And
Can you suggest a good power supply budget $44
Thanks.
