Compatibility Problem MSI 760gma-p34
Mar 9, 2018
Greetings everyone,
I have a pc, I paid it 1300 euros 5 years ago, that give me a lot of problems: freeze continiuosly my games, crash my monitor ecc.. I brought it to a pc center where they told me the problem is my Graphic Card ( AMD Radeon R9 200 series). It s an amd card and this can give a lot of problems with games, is not the best choice for a gaming pc, so I decided to change it.
The Problem is: can I with my Mother Board (MSI 760gma-p34) use a graphic card made by nVidia? Does it gave any problems? I thinked something like an nVidia Msi GTX 1050 Ti Gaming X 4G. Do you think it could work?
Just saying "OK" to your CPU.
For comparison, see this on Tom's Hardware:
http://www.tomshardware.com/reviews/gpu-hierarchy,4388.html
You'll already see, R9 is within a wide range, so you have to find the exact type. The range is from 1050, to 1060, and any shade inbetween.
At the moment, anything beyond 1050ti does not have a good price-performance relationship, while the 1060 is in fact the desired strength for FullHD at max details.
If you have the budget, yes, the 1050 Ti 4G is a very good choice in its own right.
It will work with your motherboard.
Still i have some questions for a final verdict:
- Which CPU do you use?
- Which model is your old AMD card exactly? (to be able to tell you how much faster a 1050ti will be)
Going to a shop is a good idea, if they usually repair PCS, and if the shop says, it is broken, then, yes, exchange it.
But, normally, a R9 is not necessarily a bad card for gaming, and the R9 290 is definitely faster than the 1050 Ti.
What did they say exactly was the problem with the card?
The cpu is AMD Athlon 64. Unfortunately if i check the name of graphic card with Gpu-Z or with the prompt dxdiag the name is not specified more than "AMD Radeon R9 200 series". The problem for the cp center was in the graphic card: they tried different solution but nothing seems to tell us what the precise problem is. The conclusion for them is to change the whole card, maybe is a manufacturing problem or maybe it s that specific model of graphic card installed that it s not optimized for gaming, they couldn t say me more. I don't want even to retry another repair (to much tries and i simply want to change it to eliminate the whole problem). Do you think the cpu can give problems with a nvidia card?
Ok, let's assume the shop is right.
The board you have looks ok by its spec, it's an AM3+ board, and not too old.
The price of your rig was mainly influenced by the R9 (most probably a R9 290), which was the flagship gaming card of AMD at that time.
The 1050 Ti is a good card, and with an AM3+ board it is a good combo, for playing at FullHD at medium details.
On your board runs anything from an venerable Athlon II X2, (or even a Sempron), up to a (quite more capable) AMD FX 8370.
To not throttle your 1050Ti, it should be an AMD FX 6300 at least, maybe an AMD FX 8300, or, this requires a good top-down cooler, the AMD FX 8350.
The problem is here, i still don't know which CPU you have... AMD Athlon 64 is a very generic name. Can you use CPU-Z on this?
I just used cpu-z again to check what you asked. The cpu is AMD FX 8350 8-core processor. Can you sugguest an equivalent nvidia card, if you think the 1050 ti its not comparable?
