Compatible CPU cooler with my pc
Hankthunderskull
39
Specs:
-current gpu- msi gtx 970
-Mother board: Gigabyte b85 - hd3
-Intel core i5-4690k 3.50ghz
-8gb of ram (4 x 2)
- corsair cx750
- wd10ezex 1tb hdd
Just wondering whether or not this cooler will fit or work with my pc.
This is my case: http://www.amazon.co.uk/dp/B0064LFTR8/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B005G9D2T6&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=1YDPQZH4RER5DST0G6PZ
and this is the cooler I was thinking of getting: http://www.amazon.co.uk/gp/product/B005HIRDUA?keywords=cpu%20cooler&qid=1450117760&ref_=sr_1_12&sr=8-12
thanks.
You can't overclock on a b series board you know mate.
If the cooler is just for less noise/lower temps then grab the deepcool s40 is my 5 advice.
Pre applied paste, easy to fit , lot better than the tx3 evo.
DEEPCOOL Tower Fan Computer Radiator GAMMAXX S40 Heat Sink with Cooling Fans, let your PC Case and CPU Cooler, 120mm Damping PWM Tower Fan/4 pcs 6mm Heat Pipe/Dual Airflow Channel Auxiliary Cooling Design https://www.amazon.co.uk/dp/B00HXH8TAG/ref=cm_sw_r_other_awd_6ZWBwbGSGJK6V
Best bang for the money.
Best budget cooler on the market.
Image from: techpowerup.com
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler (£24.99 @ Ebuyer)
Total: £24.99
Generated by PCPartPicker 2015-12-14 18:54 GMT+0000
http://www.hitechlegion.com/reviews/cooling/heatsinks/42980-cryorig-h7-universal-cpu-cooler-review?showall=&start=3
Review from hitechlegion ^
[video="https://www.youtube.com/watch?v=kNF-GHQthro"][/video]
Simple installation video here ^
Unmatched Compatibility
Zero RAM Interference
Focusing on providing the widest range of
compatibility, the H7 utilizes an asymmetric slanted
heatpipe layout to move the heatsink away from the
RAM zone, Offering optimal compatibility for RAM
with tall heat spreaders on both Intel 115X and
AMD platforms.
Image from: proclockers.com
[video="https://www.youtube.com/watch?v=KrROVq0cdCY"][/video]
