Current component list:
Motherboard: Gigabyte GA-970A-D3P ATX
CPU: AMD FX8350 Black Edition 8 Core
GPU: nVidia Quadro K620 http://www.nvidia.com/object/quadro-desktop-gpus.html
RAM: HyperX Fury 8GB 1866Hz (Single stick RAM, potentially adding another in due time)
Storage: SanDisk SDSSDP-128G-G25 SSD Sata III
WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue
PSU: Corsair CS450M 450W Semi-Modular 80 Plus Gold Power Supply Unit
Case: Fractal Design Arc Midi R2 (Solid side panel preferably for the extra fan spot)
CPU Cooling: Noctua NH-D15 high end air-cooler
Concerns:
Can everything be connected and powered?
Will it all fit in the case?
How will the two front USB 3.0 ports on the case be connected?
How will the case power switch be connected?
Is the mobo chipset right?
Can I use dual monitors?
What capacity power supply will I need? Online calculator estimates 378W. Should I use 550W instead of 450W so that the PSU isn't running near max?
Can I use 3 case fans and 2 CPU cooler fans?
Do any of the components stand out as unnecessary/outdated/easily and cheaply upgradeable?
Cheers
Concerns:
Cheers
