Component Configuration Help for Adobe Illustrator
VladRaymond
Hello Friends,
I am facing a lot of difficulty in using Adobe Illustrator for the designing work that I do. I want to upgrade my components to be able to use Ai totally smoothly.
It would be very nice if you all could suggest me a good CPU configuration. I am pasting the current details of my CPU here so that you guys get an idea of what I am working on right now.
Thanks guys.
CPU-Z TXT Report
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.747 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name AMD Sempron 145
Codename Sargas
Specification AMD Sempron(tm) 145 Processor
Package Socket AM3 (938)
CPUID F.6.3
Extended CPUID 10.6
Brand ID 9
Core Stepping DA-C3
Technology 45 nm
TDP Limit 41 Watts
Core Speed 1607.1 MHz
Multiplier x Bus Speed 8.0 x 200.9 MHz
HT Link speed 2008.8 MHz
Stock frequency 2800 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
FID range 4.0x - 14.0x
Max VID 1.350 V
# of P-States 4
P-State FID 0xC - VID 0x10 - IDD 30 (14.00x - 1.350 V)
P-State FID 0x4 - VID 0x18 - IDD 28 (10.00x - 1.250 V)
P-State FID 0x0 - VID 0x20 - IDD 27 (8.00x - 1.150 V)
P-State FID 0x100 - VID 0x26 - IDD 14 (4.00x - 1.075 V)
Package Type 0x1
Model 45
String 1 0x2
String 2 0xA
Page 0x0
CmpCap 1
ApicIdCoreSize 4
TDC Limit 30 Amps
Boosted P-States 0
Max non-turbo ratio 14.00x
Max turbo ratio 14.00x
Max CPU COF 28
Core Performance Boost no
P-State 0, FID 0xC - VID 0x10 (14.00x - 1.350 V)
P-State 1, FID 0x4 - VID 0x18 (10.00x - 1.250 V)
P-State 2, FID 0x0 - VID 0x20 (8.00x - 1.150 V)
P-State 3, FID 0x100 - VID 0x26 (4.00x - 1.075 V)
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
TSC 2812.5 MHz
PERFEVT 2812.4 MHz
Chipset
Northbridge AMD 780G rev. 00
Southbridge AMD SB700 rev. 00
Memory Type DDR3
Memory Size 2 GBytes
Channels Single
Memory Frequency 535.7 MHz (3:8)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 20
Bank Cycle Time (tRC) 27
Command Rate (CR) 1T
Uncore Frequency 2008.8 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) (00000000000000000000)
Size 2048 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-17-23 @ 461 MHz
JEDEC #2 7.0-7-7-20-27 @ 538 MHz
JEDEC #3 8.0-8-8-23-31 @ 615 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
