Hello,
Does anyone know of a reliable application that monitors your component's temperatures and usages. and your CPUs clock speed in the background but doesn't have a big impact on CPU usage? I used to use NZXT's new CAM monitoring software but every time I launch it, my CPU's clock speed shoots up to near maximum (from about 3.8 to 4.3GHz).
I use a Kraken X40 to cool my CPU. If it helps, I just overclocked my i5-4670k to 4.3GHz at a voltage of 1.23 volts and a uncore ratio of 3.5GHz, VRIN is 1.8volts. EIST is enabled but all other power saving features are off. At Idle my CPU is about 35-38 degrees according to CAM but that may be lower due to my clock speed shooting up.
Thank you in advance![Smile :) :)](/data/assets/smilies/smile.gif)
