E ec992 Reputable Jul 16, 2014 11 0 4,510 Aug 10, 2014 #1 I just need to know if these two parts are comparable with my computer my computer is the HP 700-216 the two pieces I plan in buying are the GTX 750 ti and the AMD AD 760K processor any help appreciated .
Solution Dark Lord of Tech Aug 10, 2014 There is no guarantee that the 750ti will run on the hp , the last few weeks there are several posts about these cards not running on the prebuilts. 50 \ 50 chance.
CompGee Distinguished Jan 1, 2014 1,646 2 20,415 Aug 10, 2014 #2 Does the motherboard have an AMD or Intel chipset? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,625 1,783 159,590 Aug 10, 2014 Solution #3 There is no guarantee that the 750ti will run on the hp , the last few weeks there are several posts about these cards not running on the prebuilts. 50 \ 50 chance. Upvote 1 Downvote Solution
prit87 Splendid Jun 16, 2014 6,457 0 22,960 Aug 10, 2014 #4 yes both your cpu and gpu are compatible with the hp 700 - 120 Upvote 0 Downvote
E ec992 Reputable Jul 16, 2014 11 0 4,510 Aug 10, 2014 #5 My mistake my computer is the 700-216 Upvote 0 Downvote
E ec992 Reputable Jul 16, 2014 11 0 4,510 Aug 10, 2014 #6 There is no guarantee that the 750ti will run on the hp , the last few weeks there are several posts about these cards not running on the prebuilts. 50 \ 50 chance. it there a way to make them work guaranteed? Upvote 0 Downvote
E ec992 Reputable Jul 16, 2014 11 0 4,510 Aug 10, 2014 #7 CompGee : Does the motherboard have an AMD or Intel chipset? AMD Upvote 0 Downvote
