Question Recommended specs for around 40 computers for educational purposes ?
Jul 16, 2024
Hello everyone, I'm new here and I hope You had some advice for me hoping my english will be sufficient:
I need new computers for our media rooms for adult education. there is a lot of teaching Photoshop and InDesign and even Shortcut or Premiere (Adobe). The current pc doesn't work well with the new developments and AI. We also teach Excel but that works just fine with the old pc. So here are my questions:
What components do You recommend for buying new PC (more or less 40 PCs in total) and what will it cost?
- CPU
- motherboard (with WiFi, Bluetooth, USB front)
- graphics card
- what kind of RAM (DDR 4, DDR 5?), 32 GB?
- only one harddisk, 1 TB would be enough
- Monitor (image editing, RAW, do you think I need the same quality for all monitors or would it suffice to have some for Photoshop and others for InDesign or Premiere?)
Price Range per PC: €1500-2000 .
It should work for at least 5 years but not high end. A lot of shifting users. We are public, education, no gaming. So it should work good but we also haven't that much money.
Thank's a lot for Your sugggestions!
Dietlindchen
js2
Jul 16, 2024
8
Depending on your network and setup you could go for a GPU server. Or even a Cloud Service.
If you are a registered charity/education you will get steep discounts, usually.
NedSmelly
687
355
770
(more or less 40 pc)
Speak with different education & enterprise volume suppliers as you’ll not only need to discuss specs, but also support agreements. What’s ideal for a freelancer and forum enthusiast is not always ideal for a lab environment. Start dialogue with usual suspects - Dell, HP, Apple, etc.
Jul 16, 2024
Thank's for Your ideas. Thing is I'll need to do a call of bids and I was interested not only in commercial opinions.
Cloud Services are not suitable. We have a freelance IT Admin who administer all educational technical devises but is not fit enough in graphic design needs to give me adequate tips. He does the support, host the servers, do IT security etc. The pc are also in use for Excel, Programming, IT for beginners so it shouldn't be Apple but an use for everyone and everything device. Problem is that the usual equipment ment for us not sufficient for image creation with AI etc. So I have to amp up our technic parc...
I was interested if You could give me tips about the specs for the graphic card (is GeForce RTZ 3070 or 3080 or ? acquired? Would AMD Radeon e.g. RX 6700 XT would also do the job)
If You thing Intel i7 (or i5) or AMD Ryzen 7 ist better or if all work?
If 32GB would be enough? And if You would recommend DDR 4 or DDR 5.
Do I need a Monitor like Dell UltraSharp or BenQ PD2700U only for Photoshop or also for InDesign.
I have to list what we need, than firms can apply. We are non-profit. It shouldn't be more expansive than necessary but it should do the job properly for at least 4-5 years.
Thx
