Components for mini ITX build
makroman
So i'm buying a miniITX based pc and I would like to be sure that I get everything right.
Components: Cpu: Intel Core i5 4670
Gpu: Nvidia GTX 670 directcu II mini
Motherboard: Gigabyte GA-H61N-USB3
Hdd: ssd or 2.5''
PSU: Cooler Master "B Series" B600 atx form factor
Ram: 8gb ddr3
Case: http://www.tweaktown.com/reviews/5644/lian-li-pc-tu100-b-mini-tower-chassis-review/index.html
Monitor: https://www.asus.com/Monitors_Projectors/MB168BPlus/
Ok so these are the components that I want to use, I need this pc to be as portable as possible but I didn't choose a laptop because I also need a strong pc for games.
So my biggest question here is, will this power supply unit fit into this small case? If not which Power supply will I need and how much Watts does it have to be to run the above build.
I wanna ask about a monitor. I like it very much and it is like a normal laptop monitor size but has full hd so I think this is great but I am concerned however about the usb connection. Is a usb connection to the pc give me any problems? This would be my main monitor so I need it to run flawlessly.
All and all any other suggestions you have I will gladly listen.
I am pretty sure that psu will fit just fine, but you should not pick that one. You should one with higher quality. I would recommend one of these http://pcpartpicker.com/part/nzxt-power-supply-np1bn055...
http://pcpartpicker.com/part/thermaltake-power-supply-s...
http://pcpartpicker.com/part/rosewill-power-supply-caps...
I can't open that links but thanks anyway. Well I checked again and it says that this particular case only supports SFX power supplies. Now that is not a problem only need to know how much Watts does it have to be to support this components. Wouldn't want to buy too little watts or too much if it is not needed.
