comprehensive SMART diagnostic.
dwc001
4
How to do SMART diagnostic after Window 7 says hard drive failure. Ran chkdsk and no bad sectors, used Toshiba diagnostic and hard drive passed. Still get windows hard drive failure, backed up pc. is there a malware software to run to check for malware as the cause?Log Name: Application
Source: Microsoft-Windows-Wininit
Date: 11/30/2015 11:46:51 AM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer:
Description:
Checking file system on C:
The type of the file system is NTFS.
Volume label is TI105949W0C.
A disk check has been scheduled.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 5)...
346880 file records processed.
File verification completed.
1635 large file records processed.
0 bad file records processed.
0 EA records processed.
63 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 5)...
448616 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 5)...
346880 file SDs/SIDs processed.
Cleaning up 1422 unused index entries from index $SII of file 0x9.
Cleaning up 1422 unused index entries from index $SDH of file 0x9.
Cleaning up 1422 unused security descriptors.
Security descriptor verification completed.
50869 data files processed.
CHKDSK is verifying Usn Journal...
35141848 USN bytes processed.
Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
346864 files processed.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
25163769 free clusters processed.
Free space verification is complete.
Windows has checked the file system and found no problems.
300485631 KB total disk space.
199193920 KB in 292497 files.
176500 KB in 50870 indexes.
0 KB in bad sectors.
460131 KB in use by the system.
65536 KB occupied by the log file.
100655080 KB available on disk.
4096 bytes in each allocation unit.
75121407 total allocation units on disk.
25163770 allocation units available on disk.
Internal Info:
00 4b 05 00 52 3d 05 00 6a b2 09 00 00 00 00 00 .K..R=..j.......
e9 39 00 00 3f 00 00 00 00 00 00 00 00 00 00 00 .9..?...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Windows has finished checking your disk.
Please wait while your computer restarts.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-11-30T17:46:51.000000000Z" />
<EventRecordID>152781</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>Donna-PC</Computer>
<Security />
</System>
<EventData>
<Data>
Internal Info:
</Data>
</EventData>
</Event>
CHK DSK log
wmic root disk drive from command prompt shows status Pred Fail.
Would it be safe to buy new drive?
Ran Malwarebyes, it fixed some issues.
Ran Toshiba Diagnostics and it said hard drive passed.
Date 2015/11/30 16:29:42
[PC Information]
Model Name Satellite L655D
Part Number PSK2LU-02900C
Serial Number 9A171487W
OS Version Microsoft Windows 7 Home Premium 6.1.7601 Service Pack 1
BIOS Version 2.00
CPU AMD Turion(tm) II P540 Dual-Core Processor
Physical Memory 4096MB RAM
Hard Disk Capacity 307,697,283,072 [Byte] 286.565 [GB]
Hard Disk Free Space Capacity 103,234,920,448 [Byte] 96.145 [GB]
Video ATI Mobility Radeon HD 4200 Series version=8.712.2.1000
Screen Resolution 1366 x 768 Pixels
Color Quality True Color (32 Bit)
Sound Conexant SmartAudio HD version=4.119.0.60
Network Realtek RTL8188CE Wireless LAN 802.11n PCI-E NIC version=1000.1.212.2010 MAC Address=1C:65:9D:62:26:56
Atheros AR8152 PCI-E Fast Ethernet Controller version=1.0.0.26 MAC Address=60:EB:69:52:EF:CD
Modem None
Internet Explorer 9.11.9600.18097
IDE Device TOSHIBA MK3265GSXN ATA Device
MATSHITA DVD-RAM UJ890AS ATA Device FW version=1.40
[QFE Information]
Windows Update "KB2849697"
Windows Update "KB2849696"
Windows Update "KB2841134"
Windows Update "KB2670838"
Windows Update "KB971033"
Windows Update "KB917607"
Windows Security Update "KB2305420"
Windows Security Update "KB2393802"
Windows Security Update "KB2425227"
Windows Security Update "KB2446710"
Windows Security Update "KB2475792"
Windows Security Update "KB2476490"
Windows Security Update "KB2478662"
Windows Security Update "KB2479628"
Windows Security Update "KB2479943"
Windows Update "KB2484033"
Windows Security Update "KB2485376"
Windows Update "KB2487426"
Windows Update "KB2488113"
Windows Security Update "KB2491683"
Windows Update "KB2492386"
Windows Security Update "KB2503658"
Windows Security Update "KB2503665"
Windows Update "KB2505438"
Windows Update "KB2506014"
Windows Security Update "KB2506212"
Windows Security Update "KB2506223"
Windows Update "KB2506928"
Windows Security Update "KB2507618"
Windows Security Update "KB2507938"
Windows Security Update "KB2508272"
Windows Security Update "KB2508429"
Windows Security Update "KB2509553"
Windows Update "KB2511250"
Windows Security Update "KB2511455"
Windows Update "KB2515325"
Windows Security Update "KB2518869"
Windows Update "KB2522422"
Windows Security Update "KB2524375"
Windows Security Update "KB2525694"
Windows Update "KB2529073"
Windows Security Update "KB2532531"
Windows Update "KB2533552"
Windows Update "KB2533623"
Windows Update "KB2534366"
Windows Security Update "KB2536275"
Windows Security Update "KB2536276"
Windows Security Update "KB2539635"
Windows Update "KB2541014"
Windows Security Update "KB2544893"
Windows Update "KB2545698"
Windows Update "KB2547666"
Windows Update "KB2552343"
Windows Security Update "KB2555917"
Windows Security Update "KB2556532"
Windows Security Update "KB2560656"
Windows Security Update "KB2562937"
Windows Update "KB2563227"
Windows Security Update "KB2563894"
Windows Security Update "KB2564958"
Windows Security Update "KB2567053"
Windows Security Update "KB2567680"
Windows Update "KB2570791"
Windows Security Update "KB2570947"
Windows Security Update "KB2572077"
Windows Security Update "KB2579686"
Windows Security Update "KB2584146"
Windows Security Update "KB2585542"
Windows Security Update "KB2588516"
Windows Update "KB2603229"
Windows Security Update "KB2604115"
Windows Update "KB2607712"
Windows Update "KB2616676"
Windows Security Update "KB2617657"
Windows Security Update "KB2618451"
Windows Security Update "KB2619339"
Windows Security Update "KB2620704"
Windows Security Update "KB2620712"
Windows Security Update "KB2621440"
Windows Security Update "KB2631813"
Windows Security Update "KB2633873"
Windows Update "KB2633952"
Windows Hotfix "KB2639308"
Windows Security Update "KB2639417"
Windows Update "KB2640148"
Windows Security Update "KB2641653"
Windows Update "KB2641690"
Windows Security Update "KB2644615"
Windows Security Update "KB2645640"
Windows Security Update "KB2647518"
Windows Update "KB2647753"
Windows Security Update "KB2653956"
Windows Security Update "KB2654428"
Windows Security Update "KB2655992"
Windows Security Update "KB2656356"
Windows Security Update "KB2656373"
Windows Security Update "KB2656411"
Windows Security Update "KB2658846"
Windows Security Update "KB2659262"
Windows Update "KB2660075"
Windows Security Update "KB2660465"
Windows Security Update "KB2660649"
Windows Update "KB2661254"
Windows Security Update "KB2665364"
Windows Security Update "KB2667402"
Windows Security Update "KB2676562"
Windows Update "KB2677070"
Windows Hotfix "KB2679255"
Windows Update "KB2685811"
Windows Update "KB2685813"
Windows Security Update "KB2685939"
Windows Security Update "KB2686831"
Windows Security Update "KB2688338"
Windows Security Update "KB2690533"
Windows Security Update "KB2691442"
Windows Security Update "KB2695962"
Windows Security Update "KB2698365"
Windows Update "KB2699779"
Windows Security Update "KB2705219"
Windows Security Update "KB2709162"
Windows Update "KB2709630"
Windows Security Update "KB2709715"
Windows Security Update "KB2712808"
Windows Security Update "KB2718523"
Windows Update "KB2718704"
Windows Update "KB2719857"
Windows Security Update "KB2719985"
Windows Security Update "KB2724197"
Windows Update "KB2726535"
Windows Security Update "KB2727528"
Windows Update "KB2729094"
Windows Security Update "KB2729452"
Windows Update "KB2731771"
Windows Security Update "KB2731847"
Windows Update "KB2732059"
Windows Update "KB2732487"
Windows Update "KB2732500"
Windows Update "KB2735855"
Windows Update "KB2736233"
Windows Security Update "KB2736422"
Windows Update "KB2739159"
Windows Update "KB2741355"
Windows Security Update "KB2742599"
Windows Security Update "KB2743555"
Windows Update "KB2749655"
Windows Update "KB2750841"
Windows Security Update "KB2753842"
Windows Update "KB2756822"
Windows Security Update "KB2756921"
Windows Security Update "KB2757638"
Windows Security Update "KB2758857"
Windows Update "KB2761217"
Windows Security Update "KB2761226"
Windows Update "KB2762895"
Windows Update "KB2763523"
Windows Security Update "KB2769369"
Windows Security Update "KB2770660"
Windows Update "KB2773072"
Windows Security Update "KB2778344"
Windows Security Update "KB2778930"
Windows Security Update "KB2779030"
Windows Update "KB2779562"
Windows Security Update "KB2785220"
Windows Update "KB2786081"
Windows Update "KB2786400"
Windows Security Update "KB2789645"
Windows Security Update "KB2790113"
Windows Security Update "KB2790655"
Windows Update "KB2791765"
Windows Update "KB2798162"
Windows Security Update "KB2799494"
Windows Update "KB2799926"
Windows Update "KB2800095"
Windows Security Update "KB2803821"
Windows Security Update "KB2804579"
Windows Security Update "KB2807986"
Windows Update "KB2808679"
Windows Security Update "KB2808735"
Windows Security Update "KB2813170"
Windows Security Update "KB2813347"
Windows Security Update "KB2813430"
Windows Update "KB2813956"
Windows Security Update "KB2820197"
Windows Update "KB2820331"
Windows Security Update "KB2829361"
Windows Security Update "KB2830290"
Windows Security Update "KB2832414"
Windows Security Update "KB2833946"
Windows Update "KB2834140"
Windows Security Update "KB2834886"
Windows Security Update "KB2835361"
Windows Security Update "KB2835364"
Windows Update "KB2836502"
Windows Update "KB2836942"
Windows Update "KB2836943"
Windows Security Update "KB2839894"
Windows Security Update "KB2840149"
Windows Security Update "KB2840631"
Windows Update "KB2843630"
Windows Security Update "KB2844286"
Windows Security Update "KB2845187"
Windows Security Update "KB2845690"
Windows Update "KB2846960"
Windows Hotfix "KB2847077"
Windows Security Update "KB2847311"
Windows Security Update "KB2847927"
Windows Security Update "KB2849470"
Windows Security Update "KB2850851"
Windows Update "KB2852386"
Windows Update "KB2853952"
Windows Security Update "KB2861191"
Windows Security Update "KB2861698"
Windows Security Update "KB2861855"
Windows Security Update "KB2862152"
Windows Security Update "KB2862330"
Windows Security Update "KB2862335"
Windows Security Update "KB2862966"
Windows Security Update "KB2862973"
Windows Update "KB2863058"
Windows Security Update "KB2863240"
Windows Security Update "KB2864058"
Windows Security Update "KB2864202"
Windows Security Update "KB2868038"
Windows Update "KB2868116"
Windows Security Update "KB2868623"
Windows Security Update "KB2868626"
Windows Security Update "KB2868725"
Windows Security Update "KB2871997"
Windows Security Update "KB2872339"
Windows Security Update "KB2875783"
Windows Security Update "KB2876284"
Windows Security Update "KB2876315"
Windows Security Update "KB2876331"
Windows Update "KB2882822"
Windows Security Update "KB2883150"
Windows Security Update "KB2884256"
Windows Security Update "KB2887069"
Windows Update "KB2888049"
Windows Update "KB2891804"
Windows Security Update "KB2892074"
Windows Security Update "KB2893294"
Windows Update "KB2893519"
Windows Security Update "KB2893984"
Windows Security Update "KB2894844"
Windows Security Update "KB2898785"
Windows Security Update "KB2898857"
Windows Security Update "KB2900986"
Windows Security Update "KB2901112"
Windows Update "KB2904266"
Windows Update "KB2908783"
Windows Security Update "KB2909210"
Windows Security Update "KB2909921"
Windows Security Update "KB2911501"
Windows Security Update "KB2912390"
Windows Update "KB2913152"
Windows Update "KB2913431"
Windows Security Update "KB2913602"
Windows Security Update "KB2916036"
Windows Update "KB2918077"
Windows Security Update "KB2918614"
Windows Update "KB2919469"
Windows Security Update "KB2922229"
Windows Security Update "KB2925418"
Windows Security Update "KB2926765"
Windows Update "KB2928562"
Windows Security Update "KB2929437"
Windows Update "KB2929733"
Windows Update "KB2929755"
Windows Security Update "KB2929961"
Windows Security Update "KB2930275"
Windows Security Update "KB2931356"
Windows Security Update "KB2936068"
Windows Security Update "KB2937610"
Windows Security Update "KB2939576"
Windows Security Update "KB2943357"
Windows Update "KB2952664"
Windows Security Update "KB2957189"
Windows Security Update "KB2957503"
Windows Security Update "KB2957509"
Windows Security Update "KB2961072"
Windows Update "KB2966583"
Windows Security Update "KB2968294"
Windows Update "KB2970228"
Windows Security Update "KB2971850"
Windows Security Update "KB2972100"
Windows Security Update "KB2972211"
Windows Security Update "KB2972280"
Windows Security Update "KB2973112"
Windows Security Update "KB2973201"
Windows Update "KB2973337"
Windows Security Update "KB2973351"
Windows Security Update "KB2976627"
Windows Security Update "KB2976897"
Windows Security Update "KB2977292"
Windows Security Update "KB2977629"
Windows Hotfix "KB2977728"
Windows Update "KB2978092"
Windows Security Update "KB2978120"
Windows Security Update "KB2978668"
Windows Security Update "KB2978742"
Windows Security Update "KB2979570"
Windows Update "KB2980245"
Windows Update "KB2981580"
Windows Security Update "KB2982378"
Windows Security Update "KB2984972"
Windows Update "KB2985461"
Windows Security Update "KB2991963"
Windows Security Update "KB2992611"
Windows Update "KB2993651"
Windows Security Update "KB2993958"
Windows Update "KB2998527"
Windows Update "KB2999226"
Windows Update "KB3001554"
Windows Security Update "KB3002885"
Windows Security Update "KB3003057"
Windows Security Update "KB3003743"
Windows Security Update "KB3004361"
Windows Security Update "KB3004375"
Windows Security Update "KB3005607"
Windows Update "KB3006121"
Windows Hotfix "KB3006137"
Windows Security Update "KB3006226"
Windows Update "KB3006625"
Windows Update "KB3008627"
Windows Security Update "KB3010788"
Windows Security Update "KB3011780"
Windows Update "KB3013531"
Windows Security Update "KB3019215"
Windows Security Update "KB3019978"
Windows Update "KB3020338"
Windows Update "KB3020369"
Windows Update "KB3020370"
Windows Security Update "KB3021674"
Windows Security Update "KB3022777"
Windows Security Update "KB3023215"
Windows Security Update "KB3030377"
Windows Security Update "KB3031432"
Windows Security Update "KB3032655"
Windows Security Update "KB3033889"
Windows Security Update "KB3033890"
Windows Security Update "KB3033929"
Windows Security Update "KB3035126"
Windows Security Update "KB3035132"
Windows Update "KB3035583"
Windows Security Update "KB3037574"
Windows Update "KB3040272"
Windows Security Update "KB3042553"
Windows Security Update "KB3045685"
Windows Security Update "KB3046017"
Windows Security Update "KB3046269"
Windows Update "KB3054476"
Windows Security Update "KB3055642"
Windows Security Update "KB3059317"
Windows Security Update "KB3060716"
Windows Security Update "KB3061518"
Windows Security Update "KB3067903"
Windows Update "KB3068708"
Windows Security Update "KB3069392"
Windows Security Update "KB3071756"
Windows Security Update "KB3072305"
Windows Security Update "KB3072630"
Windows Security Update "KB3072633"
Windows Security Update "KB3074543"
Windows Security Update "KB3075220"
Windows Update "KB3075249"
Windows Security Update "KB3076895"
Windows Security Update "KB3076949"
Windows Update "KB3077715"
Windows Security Update "KB3078601"
Windows Update "KB3078667"
Windows Update "KB3080149"
Windows Security Update "KB3080446"
Windows Security Update "KB3081320"
Windows Security Update "KB3084135"
Windows Security Update "KB3086255"
Windows Security Update "KB3087039"
Windows Security Update "KB3087918"
Windows Security Update "KB3092601"
Windows Update "KB3092627"
Windows Security Update "KB3093513"
Windows Security Update "KB3097877"
Windows Security Update "KB3097966"
Windows Security Update "KB3097989"
Windows Security Update "KB3100213"
Windows Security Update "KB3100773"
Windows Security Update "KB3101246"
Windows Security Update "KB3101722"
Windows Security Update "KB3101746"
Windows Update "KB3102810"
Windows Update "KB3107998"
Windows Update "KB958488"
Windows Update "KB976902"
Windows Service Pack "KB976932"
Windows Update "KB982018"
[Diagnostic Results]
HARDDISK DRIVE TEST (C:\) DONE PASS
Now what?
I ran Toshiba diagnostic and listed results. It said hard drive passed. I ran malwarebyes and it fixed some issues. I still get error message about hard drive. Could it be network drivers? I backed up system and bought a new drive. Should I just go ahead and change drive? I have bought new drive and backed up system
Welcome to the community, dwc001!
@popatim is right, it's highly recommended to perform the HDD diagnostic test using your manufacturer's diagnostic tool. Chkdsk is a two-edged sword, so be careful when you run it. I'd also strongly recommend you to backup your data from the hard drive before proceeding with the troubleshooting.
The HDD can always be replaced, but if you don't have a backup of your files you might lose them.
I'd also check if your HDD is still under warranty using the manufacturer's website to do a warranty check.
Good luck! Keep us posted! :)
SuperSoph_WD
Ran Had diagnostic from manufacturer, shows hard drive passed. I bought new internal hard drive and backed up computer. I was told virus or malware could cause this, but I ran Kaspersky and malwarebytes with no alerts. Should I just go ahead and change drive?
