[SOLVED] Computer and Audio Stutters/Distorts Every Few Seconds
artavasdes
121
8
615
My computer stutters and the audio distorts every few seconds. While in game, the frames seem to drop every few seconds and the stuttering continues. I just wanted to mention that I know the cpu is going to be bottlenecking the gpu, I hope to replace the cpu soon. I recently got the rtx 3090 and replaced the previous rx 5700xt.
The specs are as follows:
CPU: Ryzen 7 3700x
GPU: RTX 3090
RAM: Crucial Ballistix 4x8gb 4000 mhz
Motherboard: Gigabyte x570 aorus elite
PSU: ROG Thor 1200 watt
I Thought the issue might have been ram, but I enabled the xmp and nothing changed, the stuttering still continued. I wanted to mention how it does not feel too much like stuttering, but more like frame drops even when not in a game.
Thanks for any help!
I would try removing the mobo audio drivers first and restarti g the system then giving audio a shot.
Thanks for the suggestion. I ended up resetting windows and the problem's solved, no more stuttering or distortion. I really wonder what caused it. It might be the audio drivers like you said.
7/19/21 EDIT: I just wanted to mentioned that the issue was most likely from a Virtual machine software I had installed (I forgot if it was virtualbox or vmware).
CPU: Ryzen 7 3700x
GPU: RTX 3090
Did you make sure the bios is fully up to date? You'll want to do that anyways before ugrading anyhigher into cpus anyways.
CPU: Ryzen 7 3700x
GPU: RTX 3090
And you have all the latest mobo drivers?
