computer build help
jakemangoes
38
i just powered up my build for the first time to see if everything is working and it turns on and lights up and everything but it also sends off a alarm like noise and im not sure whats causing it...any help?
We'll need a little more info here, what are you build specs? Often the CPU led is a single color (red most common) - alarm noises at first boot are usually related to the CPU fan not being plugged into the CPU fan header (or not all the way in). There may be other causes though - the build info should help
Similar threads
