Hi I'm trying to build my first computer and I wanted to make sure that all my parts were compatible and st the same time wanted some suggestions. On a budget trying to spend under 500. Here is what I have so far:
Rosewell Challenger mid-tower $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Biostar mobo $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138318
Sapphire Radeon 6770 $119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102940
Antec 550w psu $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
Amd Athlon x2 265 3.3 Ghz $69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103910
Gskill 2gb ddr3 $14.99x2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231252
Western digital caviar blue 320gb 7200rpm $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136770
Any help would be greatly appreciated
Biostar mobo $69.99
