A while back on my wife's PC the front case fan (2) stopped working but still lit up with the LED lights. It did work on mine but I chalked it up as it possibly just stopped working.
Well today I re wired my PC and try and clean it up and now the same front case fan (2) stopped working for me as well, but the LED is still lit. At this point I figured maybe I am doing something wrong.
They are both plugged into the mobo on fan 2 and when going into the bios there is no sign of fan 2, 1 and 3 are present. They are three prong pins. Again when I first hooked everything up they both worked just fine.
They are both powered to the same power supply connector line with fan 1. Fan 3 on both have their own power supply line running to the power supply. Can that be the problem? Could both being connected to the same power line to the power supply not be enough juice for the two?
Maybe they both just stopped working and I am just losing my mind.
I have a ASUS 970 Pro gaming mobo
Both have AMD processors, one is eight core and other is quad core.
Thank you for your time.
