Computer components give me an electrical shock when touched.
Toshz
156
Hey Guys,
I have just "built" my gaming computer, I still do not have a case as I'm still undecided so I have built it on a cardboard box 😀
However everytime I try to plug/unplug a usb device or touch any of my hard drives I get an electrical shock. Is this a bad sign?
Kinda worried here, would appreciate any help. I just turned my PSU switch off just in case.
Just the metal parts, the GPU does not shock me.
oh, do you have the cardboard box on carpet and have it move around. Or are you wearing socks on carpet while touching the hard drive. Because that can build up an electrical charge and then you touch the metal pieces which causes that to get discharged sorry if it seams stupid questions but just gotta make sure.
Yes I do, I currently have it connected to an outlet and the 3 pins are in.
I will give it a try connecting it directly to the wall socket.
I just hope he hasn't broken anything yet and sorry for the noobness of this but what is the spu
No, I have it on top of a wooden table and I do not have carpet on my floor it's just tiles.
I have a Rosewill Capstone 550W Gold rated PSU.
Sorry, typo - I was reffering to the PSU.
One way to ground yourself before touching any PC component everytime, is to touch your PSU while it`s connected to the grounded wall socket, even if the PSU is switched off.
OH there we go I was looking all over the internet all confused now it makes since
Well in this case there is 2 options you can go on and install windows to see if it will and just not touch anything in the cardboard. Or you can wait to get an actual case and see if that helps it not shock you
hmm maybe i'm not super familiar with crocs but aren't they mostly rubber that could help discharge any electricity generated from you
Yeah, they are all rubber.
Good then my idea would be to continue with installing windows for now and just get a case ASAP and if you need to do some tinkering with the internals just put on those crocs kinda wierd that a wood desk and hardwood floor would gather electricity though
Crocs will not "discharge" you. The reason that you are getting a shock is because there is a potential difference (voltage) between you and the earth circuit of your computer. This can mean two things.
1: you are becoming repeatedly statically charged. This will result in a flow of current between you and the earth circuit on your computer. Crocs may stop you becoming charged, but they will not stop you discharging.
2: you have a live current flowing through the earth circuit of your computer. This is normal to a certain extent, as many electronic components "bleed" to earth, but the fact that you are getting shocks is not normal. The voltage of the earth should not be high enough to penetrate your skin, and the earth of your mains circuit should present an "easier path" for the current anyway. I would suggest you try different sockets in different rooms, and call an electrician if necessary.
I am currently not getting shocks anymore, is it possible that the wifi antenna had something to do with it?
that is the only thing i have removed since and im not getting any more shocks, everything is working great atm, installed windows and drivers.
