Is this possible? I just built a new PC - Gigabyte GA-G31M-ES2L MB, Core 2 Wolfdale 8400 3.0gHz with Intel boxed fan, basic case with 120mm fan (3 wire connect.)
Problem? Maybe?
The processor fan and system fan are each running at 800rpm. Now before you jump the gun, the processor is cool as a cucumber at 15 degrees Centigrade. I don't know if there actually is a problem but it is so quiet I actually turned it off at initial boot to be sure I wasn't frying the processor. The power supply (new Corsair 550w) fan also is running but it's also quiet and isn't laboring or tornadic, it just runs and seems OK. One 7500rpm HDD, one simple DVD drive, no other cards and no other software running other than XP and the MB drivers.
Could it be that the system is just operating fine and the fans are nearly unnecessary in my cooler workspace? I thought about pushing the processor a bit to see if the fan speeds would rise automatically, but just didn't go there yet.
Looking for your thoughts. Thanks!![Smile :) :)](/data/assets/smilies/smile.gif)
Problem? Maybe?
