Computer Hangs/Freezes and Emits a Loud Freaky Sound From Speakers
EdwardJenkinsS
81
Hello! I'm writing this because my baby is having some issues. I recently built this PC in June.
Specs
As you can see, my hardware really isn't old. I don't know why I am having this issue. I have run HD tune and it says both my HDD and SSD are in good health. Memtest successfully completed 1 pass with no errors, but i understand I may need to do more(perhaps this is it?). The freezes do not occur when I am playing video games, but mainly when I am watching Twitch.tv. There is no blue screen, no error number, just freeze. loud sound. Then I have to restart it.
I figured the games I play would be enough to test the GPU. Such as Killing Floor 2 at max settings with gore physics enabled. No freezes. GPU temps are never above 71 Celsius. CPU temps are never above 60 Celsius. Hmm... did I forget anything? Oh yes, I have checked all of the drivers for all of my devices. And windows says they are all up to date. The only thing I am doing now, is installing updates for windows 8.1.
Hoping that maybe this is the issue. Any other ideas or suggestions would be greatly appreciated.
I would love to get my baby back in good health. These freezes are getting annoying, and seemingly more frequent? Not quite sure, at the end of the day. I just know that it is certainly not good.
Event 41 is hard explained so i just post a solution to it.
Youtube
Event 6008 is a bug you can iggnore this, it DOES NOT effect your system.
Event 27 suggest there is something rong with your chipset drivers. Reinstall from vendor and see if it settles.
Assuming you have checked device manager and there is no conflicts.
If it's a new problem start by checking windows restore to see what you installed when the problem started to occur.
Win key + R type "rstrui.exe" choose a restore point and pretend you're about to restore to that point and you should see a list of installed software that will be changed, aka was installed then.
Check the mb screws, not to tight not to lose.
Check the cables connections.
Did you apply correct amount of thermal paste? That is like a grain. A very very this layer between cpu and the H212.
Check the event log for clues.
I checked the connections, everything seems fine. The correct amount of paste was applied. it was about the size of a pea. Though I could reapply it. Installed programs don't seem to mention anything huge. For example,
Avast.
GeForce Experience stuff.
Drivers for graphics,
Sound Blaster Recon 3Di
Avast net service
Intel(Net)
intel(NetTrans)
However the event log mentions some interesting things
This critical error was logged right before I shut it down I presume. Note there is no BSOD, or any thing like that. Just freeze, loud noise. I turn it off using the power button by holding it. Restarts in about 15 seconds, and everything is fine. Also the drivers don't show any conflicts, and windows says all drivers are up to date.
Critical Error shows this:
+ System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 3
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2015-10-11T01:10:15.213182000Z
EventRecordID 505260
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer TheBeast
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
or XML:
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>3</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2015-10-11T01:10:15.213182000Z" />
<EventRecordID>505260</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>TheBeast</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
</EventData>
</Event>
Also some more errors that are close to the times of the freeze.
+ System
- Provider
[ Name] EventLog
- EventID 6008
[ Qualifiers] 32768
Level 2
Task 0
- TimeCreated
[ SystemTime] 2015-10-11T01:10:18.000000000Z
EventRecordID 505249
Channel System
Computer TheBeast
Security
- EventData
9:06:30 PM
‎10/‎10/‎2015
36005
DF070A0006000A00150006001E005003DF070A0000000B00010006001E005003600900003C000000010000006009000001000000B00400000100000000000000
Binary data:
In Words
0000: 000A07DF 000A0006 00060015 0350001E
0010: 000A07DF 000B0000 00060001 0350001E
0020: 00000960 0000003C 00000001 00000960
0030: 00000001 000004B0 00000001 00000000
In Bytes
0000: DF 07 0A 00 06 00 0A 00 ß.......
0008: 15 00 06 00 1E 00 50 03 ......P.
0010: DF 07 0A 00 00 00 0B 00 ß.......
0018: 01 00 06 00 1E 00 50 03 ......P.
0020: 60 09 00 00 3C 00 00 00 `...<...
0028: 01 00 00 00 60 09 00 00 ....`...
0030: 01 00 00 00 B0 04 00 00 ....°...
0038: 01 00 00 00 00 00 00 00 ........
and XML for that one
- <System>
<Provider Name="EventLog" />
<EventID Qualifiers="32768">6008</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2015-10-11T01:10:18.000000000Z" />
<EventRecordID>505249</EventRecordID>
<Security />
</System>
- <EventData>
<Data>9:06:30 PM</Data>
<Data>‎10/‎10/‎2015</Data>
<Data />
<Data />
<Data>36005</Data>
<Data />
<Data />
<Binary>DF070A0006000A00150006001E005003DF070A0000000B00010006001E005003600900003C000000010000006009000001000000B00400000100000000000000</Binary>
</EventData>
</Event>
And also this one:
+ System
- Provider
[ Name] e1rexpress
- EventID 27
[ Qualifiers] 40964
Level 3
Task 0
- TimeCreated
[ SystemTime] 2015-10-11T01:10:22.110957200Z
EventRecordID 505276
Channel System
Computer TheBeast
Security
- EventData
Intel(R) I210 Gigabit Network Connection
0000040002003000000000001B0004A00000000000000000000000000000000000000000000000001B0004A0
Binary data:
In Words
0000: 00040000 00300002 00000000 A004001B
0010: 00000000 00000000 00000000 00000000
0020: 00000000 00000000 A004001B
In Bytes
0000: 00 00 04 00 02 00 30 00 ......0.
0008: 00 00 00 00 1B 00 04 A0 .......
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: 1B 00 04 A0 ...
and XML
- <System>
<Provider Name="e1rexpress" />
<EventID Qualifiers="40964">27</EventID>
<Level>3</Level>
<Task>0</Task>
<TimeCreated SystemTime="2015-10-11T01:10:22.110957200Z" />
<EventRecordID>505276</EventRecordID>
<Security />
</System>
- <EventData>
<Data />
<Data>Intel(R) I210 Gigabit Network Connection</Data>
<Binary>0000040002003000000000001B0004A00000000000000000000000000000000000000000000000001B0004A0</Binary>
</EventData>
</Event>
The general event names are as follows, and in order.
first is Event 41, Kernel-Power TIME: 10/10/2015 9:10:15 PM
second is Event 6008, EventLog TIME: 10/10/2015 9:10:18 PM
third is Event 27, e1rexpress TIME: 10/10/2015 9:10:22 PM
Thanks a ton for the help, it is much appreciated. I'm freaking about my computer doing this weird behavior.
Youtube
Now I am trying to eliminate this Event 27 error. I have identified that it comes from my Intel(R) I210 Gigabit Network Connection. Which is under Network Adapters. I have uninstalled it, reinstalled it, downloaded the driver multiple times now. But I still get Event 27 on startup. Any idea why this is? Do I even need this network adapter? And what kind of effect can this have on my system, if I never resolve this event? Is this a big deal?
Good news though, no more freezing. But its only been 1 day, so we're not out of the woods yet!
I also just got a new Event!
Event 123 DeviceSetupManager
Says this below it in the event window: The DSM service was delayed by 11 seconds for a driver query/download/install on device 'PCI\VEN_8086&DEV_1533&SUBSYS_00000000&REV_03\001FBCFFFF0F048900'
It deppends.
It's your ethernet connection so if you have more than one or connect wirelessly. That is if you have internet access while the driver malfunction you can disable it. If you had internet while you uninstalled it you can disable it. But if its your primery internet path to the pc you definitly need it.
Good news about the freezing! Hoop it stick! :sol:
Shouldn't be a problem. It's something to do with internet access from Windows Update. Or Windows Update rtying to get a driver for you and failed. Try to asses if you need it first.
Thanks for the links, as soon as I get home I will install these. I was looking all over for the correct things, but I would install using the Intel Driver Detection Service thing. I updated, and then I would run it again, and it wants to update the same exact driver again? Very strange, perhaps installing the drivers through this method will make things smoother.
Also I was able to eliminate Event 27 due to the fact that I still had internet when this thing "disconnected". So I assumed that it is not needed, and I disabled it as advised.
Overwriting them is what you want, the drivers wasn't rong just corrupt. It's the same version we replacing. Off corse only install 64bit drivers for ethernet (and as admin). If installed correct it should run smoother. If it works better now just restore to previous driver from device manager under right click on Windows flag or left corner.
So far so good! No freezes, no more Events logged! Everything is beautiful and you are a wizard. I'm going to go ahead and give you the best solution that you deserve! And if I have any more issues, would you mind if I just PMed you? So far everything is working perfectly! 😀
But I figured that there is no reason to keep bumping this now.
Absolutely, just pm in that case, if it runs smoot now, it's solved. Im glad i could help. I Know how it feels to have a clean eventlog and your system is to fresh to run bad. Im doing this to give back some. thw have helped me aloot when i was younger.
