Computer Lags, and glitches on a week old build. Help?
Jason19722012
To reinstall windows 7 you just need the disk . Try updating your BIOS first your system should play crysis 2 smooth as butter . After that I would do a fresh install of window's 7 go into your BIOS select you dvd drive as first boot choice save and exit .put the cd in the drive and restart your pc don't forget to press enter !
