Computer Parts Suggestions
PorscheBurrito
8
I am completely new to computer building, so I would like some advice on the parts I am getting. I have a budget of ~ $1200, so I would like to get the best, most efficient parts. This is meant to be a gaming PC, so I would like to run most/all games (Fallout 4, GTA 5, etc) at full settings 60fps.
Here's a link to my build. I haven't done a whole lot of research, so I am open to changing up parts. http://pcpartpicker.com/p/Q3pfwP
Does my power supply have a high enough wattage for my gaming? Do my CPU and GPU work well together? Will this case work and what/ how many case fans should I get?
I would like to start purchasing parts in about 2 weeks.
Overall looks pretty good but instead of buying 16gb of ram I would buy 8gb since games do not really need that much ram. And I think you will be just fine with 2 intake and 2 exhaust fans, but pick a good ones. I recommend getting EK vardar fans. I think they are pretty awesome even better than my previous noctua and corsair fans. And with savings from ram I would definitely pick a better quality power supply. 600w is enough but cx-series doesn't present very good quality Here is the list of psu tiers, I would pick one from tier1 or tier2 (your current psu is in tier4 which ones you should avoid) http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
Hi, something like this will be perfect if you're willing to spend more.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($237.98 @ Newegg)
Motherboard: Gigabyte GA-H97-D3H ATX LGA1150 Motherboard ($92.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory ($80.49 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($77.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($51.88 @ OutletPC)
Video Card: Sapphire Radeon R9 Fury 4GB Tri-X Video Card ($499.99 @ Newegg)
Case: Fractal Design Define R5 Blackout Edition w/ Window ATX Mid Tower Case ($94.99 @ NCIX US)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply ($89.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($85.98 @ OutletPC)
Total: $1312.28
Generated by PCPartPicker 2015-11-23 05:23 EST-0500
As per an on budget build;
Motherboard: ASRock Fatal1ty H97 Killer ATX LGA1150 Motherboard ($94.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($76.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($79.99 @ Amazon)
Video Card: MSI Radeon R9 390X 8GB Video Card ($399.99 @ Micro Center)
Case: Corsair SPEC-02 ATX Mid Tower Case ($49.99 @ Newegg)
Wireless Network Adapter: Asus PCE-N53 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter ($12.99 @ Newegg)
Total: $1180.77
Generated by PCPartPicker 2015-11-23 05:41 EST-0500
