My rig
I5 6600
Gigabyte ga H170-D3H
G.skill ripjaws v ddr4 ram
Seasonic g-550 modular psu(80+ gold)
No dedicated GPU, I'm using the integrated graphics on the CPU
I was using my computer when suddenly I heard a loud pop from the rig and the circuit breaker in my house tripped.
After doing much research online, my initial suspect was the psu.
I took caution and did not try to power the rig before determining the cause of the pop sound.
So I took out the psu and tried to determine if it was still functional by shorting the green to black pin . The fan was spinning and then I used a multimeter and measured all the DC voltages of all the pins on the 24 pin power connector.
I referred to the voltages in this site and they all tallied well within the tolerance range
https://www.lifewire.com/atx-24-pin-12v-power-supply-pinout-2624578
I then took apart the motherboard to inspect both side for any spoiled capacitor and all of them seem fine.
No burnt marks , no bulges ,nothing unusual.
I then reassemble the rig and booted the computer. It booted without any problem and I ran 30mins of furmark on it. Again nothing unusual.
I am worried about the loud pop that occurred am unsure of what caused it.
Could someone advise me on what I can do to determine the fault?
I have a gut feeling it's the psu that popped.
My psu is still under warranty and
if it i can conclusively decide that it is the problem , I could get it covered under the warranty.
Is there a more thorough way of determining that the psu is not spoilt besides the way I mentioned above?
I5 6600
