Computer does not receive signal upon restarting, waking from sleep, exiting BIOS, or reseting. BIOS and drivers are updated as well as RAM is running at 3000MHZ with XMP Profile enabled for dual channel. I have also cleared CMOS only to encounter the same issue. Sometimes receive one error beep code when RAM is dual channeled and other times when it is one stick. Computer can cold boot perfectly with no errors and then be restarted and get the same problem. Tested RAM in different computer and it seems to work. however when I test 1 stick in my computer and swap it with each DIMM slot it appears that the errors only occur while the RAM is not seated in A2. I have tested both sticks this way. I've ran sfc /scannow, checked both my disks for errors and ran a windows memory test on my RAM and encountered no errors. However I have encountered two BSOD on my week old system, one when waking up from sleep (computer got to the password screen and locked up) another when changing monitor settings (Error 0x0000001a. Also took whole rig apart, clean installed windows and reseated everything to the same problem. anyway to troubleshoot farther or any solutions? Going to replace motherboard soon as that is all I can think of. thanks!
Motherboard: ASRock z370 Extreme 4
GPU: EVGA 1070 TI
RAM: 2x8 GB Corsair Vengeance DDR4 3000MHZ
PSU: EVGA 650w G2
SSD: Samsung Evo 860 500 GB
HDD: WD Blue 1TB 7200rpm
hope that's everything.
GPU: EVGA 1070 TI
PSU: EVGA 650w G2
