Computer starts and stops after 3 seconds
Mykell
5
Just bought and installed my new i7 4790 cpu. Problem is, it boots for 3 seconds then stops. The fans go off and everything, it just doesnt keep running. My computer was working fine 1 hour ago, before i replaced my i3. Help!
Cpu : i7 4790
Motherboard : Gigabyte b85M-hd3
Ram : gskill ddr3 2x2g ram sticks
Power supply : Thermal Take tr2 600W
Graphics card : nvidia geforce gtx 750ti
Could be several things, but the most obvious to me would be your motherboard may need to be flashed to the latest bios to support the 4790 which is a refresh processor
I will try this right away and come back to you with the results
I just put my i3 back in and put the heatsink the same way i did on the i7 and it booted perfectly
Hey, im trying to find my motherboard bios flash but its giving me three different versions of my motherboard. The difference in the three is that it says (rev. 1.x) or (rev 2.0) or (rev. 3.0). I cant find any information about this anywhere ??
There is no 64bit compatible versinon...
I did like you said and it worked ! Thanks a lot man, been working on a solution for the past 6 hours loll
In most cases where the machine starts up then stops and starts and stops. I find the problem to generally be the power supply. They do go bad once they've been stressed a while. Try replacing the power supply and I'm sure your issue will be resolved.
