Hi Dacalos Cero
sounds like your graphics card is getting hot ,
remove it and check for dust buildup and blow it out with compressed air, also
check the cpu heatsink that it is not clogged with dust
Hi Dacalos Cero
make sure the thermal compound on your CPU and GPU/Graphics card is still good it should be sticky and white (not sure if different companies make different color thermal paste all the ones I've used have been white)
