Computer/system will not boot/start
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Computer is a Sony Vaio PCV-RS420
I replaced hard drive push start-Fans start nothing else.
Tried start-up recovery disc, CD will not start. Tried DVD slot, did not
start. Tried F2 nothing.
How do I get computer to start?
Perhaps you did not attach the cables to your
hard drive properly. Go back and double-check
all your internal cable connections.
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Be Smart! Protect Your PC!
http://www.microsoft.com/athome/security/protect/default.mspx
Thanks, for asking. Yes, all connections are secure and correct. This is a
blank HD that I'm trying to load my OS (Win XP)
> Carey Frisch
> Microsoft MVP
Open the BIOS and set your CD drive as the first bootable device.
Insert the Windows XP CD in the drive and reboot. You'll see a
message to "press any key to boot from CD...."
Carey Frisch
Microsoft MVP
Computer will not respond. Unable to access bios. Process used-Turn on PC and
hold down F2 no display
> Carey Frisch
> Microsoft MVP
Can you get to the BIOS? Is *anything* coming up on screen at all (the
P.O.S.T information etc)
Does this new hard drive have an operating system installed, or is that what
you're trying to do - install the OS from booting with the XP CD (with no
response from booting from CD).
Are your keyboard, mouse etc plugged in firmly?
Make sure that your CD & HDD ribbon cables and power cables are firmly
attached.
check back
"Richard R." <Richard R.@discussions.microsoft.com> wrote in message
news:12B9ED92-ABE2-4EAF-84E8-91EEE6949D55@microsoft.com...
Check your keyboard connection, if it's loose, that will account for the
non-response from it.
"Richard R" <Richard R@discussions.microsoft.com> wrote in message
news:C867027A-8088-43A9-AFDC-1BE0F5A3BCFE@microsoft.com...
> and
>> Carey Frisch
>> Microsoft MVP
>> is a
