Hi guys, this is my 1st post;
Very frustrated here...
I have bought a machine less than one year ago, decent one...check below specs:
Intel Core i7-6700K 4.0GHz LGA 1151 8MB
Mobo Asus Z170 Pro Gaming Aura
4x RAM Kingston HyperX Fury DDR4 8GB 2133MHz
Video card Gigabyte N GTX980WF 4GB
SSD Sandisk 480GB Ultra II Speed 550-500 MB/s
PSU Corsair CS750M 80 Plus Gold 750W
So there I was playing a game 2 days ago, suddenly my computer shuts down. I tried to turn it back on, but nothing happened. After several tests I realized that if my video card was plugged to the power cables (a pair of 6+2 cables) the computer wouldn´t turn on, but removing those cables it would turn on (no matter if the video card was connected or not to the PCIe, I tried both situations).
Further testing, I realized that it was the left side 6+2 slot that was the problem, so connecting only the right side one it would make the computer power on (but of course the video card was not on, since its fans weren´t moving).
Ok so now i knew something was wrong regarding power. Either the power supply was damaged or the video card was.... so I got a multimeter and measured the 6+2 pins from the PSU, and all measured 12V ok... so then I starting measuring the resistance in the board, and realized that in the right side slots I had like 400 ohms, while in the left side I had 1.5 ohm. Does this looks like a short ciruit to you? Shouldn´t it be similar to the other slot (400 ohms) ? How come a normal working video card suddenly short circuits? Check the picture below to understand those measurements:
https://imgur.com/a/bmBQq
I read many threads here, but most of them are for new setups so I ignored suggestions like resetting cmos, update bios.
Do you guys have any ideas/suggestions? thanks
