Computer wont display on monitor
Jan 10, 2019
my mobo is a asus prime 270 ar
the rest is here https://pcpartpicker.com/list/RwR6gw
I just bought a new case for my computer and I moved all my parts to the new case. After i finished and booted it up, it seemed normal untill nothing would show up on the monitors and after a few minutes it would turn off and then back on. a yellowish orangeish light comes on, on the motherboard. It worked fine before I switched cases no idea whats happening.
Turn off your machine and unplug it from the wall. Reset your CMOS, unplug your HDD/SSD’s and turn it on. Let it go to the BIOS. If you can get to the BIOS then turn it off, plug in your boot drive and try booting normally.
