Hi,
Yesterday, while I was browsing the web on my desktop computer, my monitor suddenly turned black and wouldn't wake up (message saying the monitor went to sleep).
Here are the symptoms:
-Monitor goes to sleep and won't wake up.
-Mouse and keyboard aren't responding (no caps/num light)
-I can hear the fans running (I can hear them, but i don't know if they're running "fast" as I've never paid attention to them before)
-I can open and close my CD drive.
-The power light on my tower turns blue when I try to launch it (which is normal... blue color when it's on, and no color when it's off) and remains blue after everything freezes.
-Right now, when I try to restart the computer, I hear the usual hardware booting sounds, but it freezes immediately when I'm on the blue hp startup screen (with only "F10=setup"... I don't have all the other options) and keyboards/mouse not working... but I can hear my computer is powered up. Monitor doesn't go to sleep, but can't do anything anyways.
I have a ~3 year old HP pavillon desktop computer. Since the purchase, I've had several problems, including a problematic wireless network card and power supply (I had to replace those 2). I've had some periods of crashes in the past which I've fixed. However, it's the first time that I can't even launch the computer to try and find the problem and fix it.
I've read many threads with the exact same problem, but the Original Posters never posted what solved their problem. The solutions proposed were very varied, but I don't have the knowledge/experience/money to try everything on my own.
Prior to this problem, my computer had been working fine for about a year (with some network problems, but I don't think it's connected to the current problem).
Any help is greatly appreciated.
Edit: so i tried several other things:
1. I have turned off my plug socket, then turned it back on, and tried to start my computer. It launched fine, but after I logged in, monitor turned black again and same problem as before.
2. I tried plugging my plug socket into another plug hole and computer launched with 1 short beep, a message about refreshing memory and BIOS (not sure... everything went fast) then I chose "launch windows as normal". After I logged in, I had a sudden crash with a blue screen message that the computer had been shutdown to prevent damage to my hardware (MEMORY_MANAGEMENT). Screen back to black, and I'm afraid to try anything else now because it could cause permanent damage? Really desperate on this one, as I have no backup of my files 🙁
I suspect it's a power supply or a memory problem, but it could also be a motherboard, bios, GPU problem... How can I know what causes this?
And how to solve a memory problem?
