Computor Power Up Problems ( Loop)
Sam12399
26
Hi, i am building a new PC and i have done it before so i know how to install all of the components but i am having a problem.
I have installed all of the components and checked everything is installed properly but when i turn it on, it powers up, the lights come on but then instantly turns off again. This then loops on and off again as do the case fans. I have tried swapping the PSU and the RAM but i have had no luck so they can be crossed off the problem list, i hope this helps.
I would appreciate the help as i have been struggling to find the problem in the past couple of days. If you need the specs there they are :
CPU: i5 4570
GPU: MSI R7 250
MBO: GA-Z87M-HD3
PSU: 450W ACE
RAM: Corsair Vengeance 2 x 8GB ram
HDD: 1TB HGST
I hope this is all the information you guys need to help me. Thanks
I have tried taking everything out of the case and powering it up but get the same results. I have a stock cooler from intel.
Hi, i have just checked the pins in the socket and there does appear to be a couple of pins that seem out of place. Would they be the problem ?
Also the power supply is out of my friends working gaming Pc so we know it works. Thanks for responding.
