I have just migrated my previous failed build from a meshlicious which I just could not get on with and with a faulty Lumen AIO into a larger Meshify 2 compact with the post recall fixed Lumen top mounted and set to exhaust air out of the case. Here I'm running OCCT and on the CPU Core Usage tab in Test I'm seeing my 12700KF''s P cores all hitting average temps of between 17 to 21 degrees on idle but all P cores with "Distance to TjMAX" hitting the low 70s to 80s. The AIO pump is running at roughly in the 4000s rpm while plugged into the AIO Pump header while all fans are around the 600s. Should I be concerned with any of this? Also the Lumen CPU block does not illuminate but I think I may need to daisy chain it to the fans since they are connected to the case's rgb controller.
Should I be concerned with my "new" build?
