Configure jumpers in IDE Disk to use two disc on the same pata cable
hardwaredrive
6
Hello folks,
I have this disks:
1-https://snag.gy/XIQKTP.jpg
2-https://snag.gy/UaXRiz.jpg
I need use this disk which on of them a master and another as slave through pata cable. I don't know how I should configure the jumpers to I can use this two disk's in same cable. Because on this disk: https://snag.gy/UaXRiz.jpg I don't know wicht I should choose, if I should choose the option "16 Heads" or "32GB Clips".
Thanks to your help,
Best Regards
You set the jumpers as Master and Slave, whichever one you want to do first.
It really doesn't matter up to the point that if it doesn't work, you just change the jumper to another one.
It won't "break" by putting the wrong jumper, it just won't work until you find the correct one.
Plug one in as Master and see if it works
remove, plug the other as Slave, see if it works
then if they both do, put them both on the cable.
