Connect 2 VGA monitors for dual screen
godlessendeavor
I'm trying to connect 2 VGA monitors to my computer. My graphic card is an Nvidia Geforce GTX660 and I'm working with Ubuntu 12.04.
I have one connector DVI-I to VGA and one DVI-D to VGA to connect the 2 monitors to the DVI ports of my graphics card. In the Nvidia X Server settings I can see that both monitors are enabled. But one of them is not running. Both monitors are running ok when plugged solely to the DVI-I connection of the graphics card. The monitors have different resolution, 1600x900 and 1280x1024 but the second one is the one that is not running (this is connected to the DVI-D port)
I know it can be drivers or even hardware related but I would like to get a clue on how to investigate this further.
Thanks in advance
I don't know about DisplayPort, but it's definitely not analog. HDMI is digital as well.
Digital>analog converters tend to be expensive and there is no way of running two analog monitors on your GPU without one.
Would it be the same for the HDMI, and Displayport? I mean, would I need active adapters for all of them?
